Discuss Advice pls: Floor has already had PVA!! in the British & UK Tiling Forum area at TilersForums.com.
N
natalleyem
Hi all
sorry it does not have a grey coating nor any visible coating.
It is quite thick and yes I agree probably a chipboard.
Builders suggested just seal it and it would be fine to tile. In fact they were supposed to seal it because I asked for marine ply in the bathroom and as I didn't get it I wanted to be sure it was waterproofed - although it shouldn't actually get wet.
Perhaps you could recommend a good sealer/waterproofer that wont' react with any floor adhesive I might use?
N
natalleyem
Thanks for all your advice :thumbsup:
so what to do about the PVA? Do I rub down the floorboarding/plaster?
Or as it's only a very watered down coating will it not matter and can I go ahead with using suggested adhesives?
and should I seal all surfaces?
I want to be sure water in the shower area will not penetrate tiles to ply/plasterboard underneath nor into floorboarding sheets and cause problems that could not be solved without ripping the tiling.
Sorry guys just want to get it right :mad2:
Reply to Advice pls: Floor has already had PVA!! in the British & UK Tiling Forum area at TilersForums.com
Hi, Need to choose a grout for the above. For the black floor tiles 300x600 am thinking either...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
