Advice Required
tileman2
Hi,
Completed training 3 weeks ago and just got my first paid job to do, Its a kitchen splashback going under units and across a window and sill, only half the windows height is being tiled. appox 5m2 in total, Im plannig on completing this in one day
Couple of quick questions
1, Obviosly im going to be doing a large amount of unusual cuts around units, ie always used the paper method ie cut a template out in paper and transfer this to the tile. Is there any other method that seems to work well.
2. The tiles are only going to be around 5/6 high and in some places only 3. Would you still use a batton as the bottom row of tiles is certainly going to be 1/2 a tile after setting out.
3. There must be 3 double sockets at least, Do you find it far easier to cut behind the sockets and then just replace the faceplates which im sure will provide a far better finish.
4. Tile trim, i need to do a three way mitre, Anyone got any quick and easy method of carying out this.
5. Grouting, Will i definately have to wait over night before grouting as i really would like to get this done and dusted in one day (if not then i will go back to ensure job is carried out spot on)
Any help/advice on the above would be great
Regards
Kev
Hi Kev.
Most of this this should have been covered in your course, but here we go:
1. Paper method is an excellent way to do this. Also, a profile gauge is another good idea. (Get them from wickes / screwfix etc)
2. You should always start with a full tile upwards from the work surface. If there is no surface, then use a baton, definately.
3. Cut behind the sockets.
4. Fine toothed saw and mitre block. Perfect.
5. You can grout same day mate.
Good luck 🙂
Hi yes this was all covered on the training, but i just wanted to find out if there were any other methods people used that may have been easier or quicker.
Quote (2. You should always start with a full tile upwards from the work surface)
Yes i understand you should start with a full tile from the work surface (make job easier) but what if that left a very thin cut (impossible cut) next to the socket or work units, then surely starting with lets say 1/2 a tile would make all cuts possible
Regards
Kev
Hi Kev,
There should be enough to cut around the sockets if your unfixing the sockets and tiling behind them. If the tiles are slither cuts close to the units, then if its under the units, you will get away with a thicker grout line (not to thick though) as it will be hidden under the unit. If its close to the pelmets, then thats the luck of the draw and you need to cut carefully. With cuts like these, its wet cut all the way, a steady hand and plenty of water.
Other options are to drop a row of tiles or choose another tile size completely.
Either way I would try and stick to a full tile upwards. 🙂
Yes the wet saw will be doing my impossible cuts if i cant get away from them, My only concern is if the work top aint level then ill have to cut the bottom row of tiles to make the first row level, still sticking to full tile from workbench upwards, Hopefully if it aint level the drop isnt that bad (it didnt look uneven to the eye).
I will be unscrewing the electrical sockets from wall and tiling behind, makes a much neater job.
the tiles im using are 8x6 that have a mosaic effect on them, they are uneven due to the grout lines and he told me they were ceramic. Are these pretty easy to cut with dry cutter.
Regards
Kev
It depends on how deep the mosaic effect is. Give them a good scoring before you pull the trigger. I would stick to wet cut though.
I always check the surface level with a spirit when I go to quote. If its not level, then I adjust my quote and advise the customer accordingly.
Good luck Kev - Drop some pics on here when your done 🙂
Hopefully the dry cutter will do the straight cuts if not like you say wet saw will do it (any tip on correct pen/pencil to use on tiles as wet cutter tends to wipe the mark off fairly easy)
Quote: I always check the surface level with a spirit when I go to quote. If its not level, then I adjust my quote and advise the customer accordingly.
Good thinking ill remember that for future, although it did look bang on
As for pics ill certainly post them on here for all to see
Regards
Kev
Hello again Kev!!
Try using a 'China Graph' pencil. You can get them from WH smiths or a good art shop.
Advice Required
tileman2,
Concept PHT,
tileman2,
Concept PHT,
