Discuss Anhydrite sceed in the UK Tiling Forum area at TilersForums.com.
Ajax123
1,213
Lincolnshire
No one else seems to be joining in this one so here goes
Sand it to clean it and remove any loose friable stuff (dirt, snots, etc) Use 60grit paper and on that size I would use rotary floor scarrifier - take maybe a couple of hours tops.
Vaccuum it to remove any remaining dust (do this thoroughly)
Make sure it's dry and make sure any underfloor heating has been comissioned and run.
Prime it with suitable primer leaving sufficient time for the primer to dry prior to doing the next bit.
Consider uncoupling membrane if heated screed (not absolute necessity but useful protection against expansion/contraction)
Stick your tiles down using a suitable adhesive.
Ajax123
1,213
Lincolnshire
Thanks Ajax for advice.. I didnt realise Lafarge was local to me so ended up going down to see them . There advice was similar to yours ..Cheers!!
similar.......SIMILAR...it should be the same not flippin similar.......where in the country are you?
Reply to Anhydrite sceed in the UK Tiling Forum area at TilersForums.com
Hi All, I have an anhydrite screeded floor that’s been down 4mths. I now need to sand it before...
I'm having a nightmare trying to establish product info from distributors. For example...
I have the old stock no more ply down unprimed. (Their new stock comes pre-primed). Mapei...
Anhydrite sceed
