Discuss anhydrite in the Canada Tile Advice area at TilersForums.com.
AD Ceramics
758
Manchester
Hi Guys
Just had the rep from Mapei out today to spec for 60m² 800x800 tiling to a kitchen on to anhydrite screed, never tiled on to an [FONT=Arial, Helvetica, sans-serif]anhydrite screed always steered clear of them, what would you use to sand the floor for the best results? he specified Mapei primer T after sanding as many coats before it stopped soaking in and kerraquid with latex plus additive, I still plan on using Ditra matting with it being a heated screed and I am thinking if I do get an area of de lamination the Ditra may help it survive.[/FONT]
[FONT=Arial, Helvetica, sans-serif]He recommended that a damp test is carried out prior to installation, the only problem is the owner of the company I work for is rush, rush, rush and whilst he will damp test it I don't think it will dry in time for my installation date of January 6th and the heating will be fired up the week after the screed has been installed, the screed is only being installed this Thursday 12th (omg that's means it's Friday 13th day after)
Any advise or info you guys could offer would be great, another company I sub to has had every anhydrite floor tiled failed by their previous tiler hence they no longer use that product for their floors.
Regards
Paul
[/FONT]
Stef
I'm very surprised Mapei said a test had to be done.
I spoke to technical & they told me that's only for wood & carpet floor coverings nothing to do with tiles as moisture can escape through the grout lines..
Lots of info on here. Personally I would contact lee @ Tiletown & order some AnhyFix as its a gypsum adhesive specifically designed for these screeds..
Chalker
1,058
Tadcaster
Floor needs to be dry, Heating needs to be tested and all this before jan, and screed not been laid yet!
try and educate your boss, buy I'm guessing he will make you do it anyway.
Disaster waiting to happen.
i know we don't live in a perfect world, but a builder I sub to works from the kitchen install backwards. Ie date for kitchen install, less testing heating, less drying time. This gives a latest date for screed to go in.
Stef
What depth is the screed going in at?
I use a drum floor sander for these screeds, hire it from Jewsons for a day.
I set a hygrometer on a floor this morning (Gyvlon) so I can get a reading for the end of the week.
This screed was poured at 55mm about 7/8 weeks ago & has been sanded & blasted with heat for a few weeks & it will be lucky if its ready to accept tiles.
There is no chance that an anhydrite screed will be ready at the start of January.
Ajax123
1,213
Lincolnshire
WTF!!! All screeds should be tested for moisture before tiling....
Ajax123
1,213
Lincolnshire
It will not be dry enough to tile by 6th jan if it's only going in tomorrow unless it is properly force dried using the underfloor heating at high temperature coupled with plenty of ventilation or extraction.
On a project at the moment where Gypsol screed has been fitted, 7 weeks or so ago, client had excellent advise all the way from Alan and Mark@tilemaster. Floor was forced dried, tested and now being tiled using TM Anhyfix. Tilers comment on site yesterday "had to get a tile up that didnt quite look right.......it was a b%£ch to get up"
AD follow the advice from the people who know what they are doing.
AD Ceramics
758
Manchester
I made an enquiry tonight with one of my suppliers regarding a gypsum based adhesive and they said there product will just go straight onto the screed, he never said anything about sanding or priming, I would never stick a tile on a any type of floor without priming, strange how they never mentioned priming to such a problematic substrate, and no mention of sanding!!!!!! any thoughts on that as I assumed the sanding was the most important first stage of installation.
Gazzer
Perhaps they dont know anything !
Reply to anhydrite in the Canada Tile Advice area at TilersForums.com
gamer1
Hi guys technical question hoping maybe you have an answer as I have never came across this...
Need some help please with calculating levels and the build up of the floor to support tiling...
6K
AD Ceramics
Manchester
anhydrite
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
