anhydrite
Apologies, what I meant was don't be pressured into doing the job if its not ready. If the builder/client is willing to wait for the screed to fully cure then that's obviously the way to go.
On a project at the moment where Gypsol screed has been fitted, 7 weeks or so ago, client had excellent advise all the way from Alan and Mark@tilemaster. Floor was forced dried, tested and now being tiled using TM Anhyfix. Tilers comment on site yesterday "had to get a tile up that didnt quite look right.......it was a b%£ch to get up"
AD follow the advice from the people who know what they are doing.
Like Ajax said why avoid, use the UFH to dry the screed, it has to be commissioned prior to tiling anyway.
Not sure again why mapei say no need to test, test every floor before applying a floor finish,
I would go with a gypsum compatible adhesive as well.
I made an enquiry tonight with one of my suppliers regarding a gypsum based adhesive and they said there product will just go straight onto the screed, he never said anything about sanding or priming, I would never stick a tile on a any type of floor without priming, strange how they never mentioned priming to such a problematic substrate, and no mention of sanding!!!!!! any thoughts on that as I assumed the sanding was the most important first stage of installation.
Perhaps they dont know anything !
There are adhesives that do not require a primer but there are none that remove the need for sanding. Which adhesive was it?
Even after all these years, Gyvlon entered the UK market in 1996!! there are still people saying utter c**p about the screed, the preparation, drying times etc etc,.
All I can say is if in doubt ask !!, we are here to help and ensure successful installation of foremost the screed but the floor finish as well.
Hi Ajax123
The adhesive that has been recommended to me is Keracol H40 Eco ideal, no primer just floor abraded and hoovered, now the word abraded would that suggest sanding, when I said scabbled oh no no no that's not good enough so abraded it is, what would you recommend to abrade the surface.
Would you install a ditra or similar anti fracture mat with an 800x800 tile, I normally wouldn't hesitate to use ditra but it has been suggested that it doesn't need it, I beg to differ but thought I would ask you guys, have any of you heard of decomat pro matting, any good?
Cheers guys
Paul
Hi Ajax123
Cheers guys
Paul
sanding and not scrabbling. Scrabbling is for concrete not screeds. So sand with medium grit paper or 60grit to remove any loose and friable material and damn good vacuum to get rid of the dust. H 40 Eco ideal is perfectly ok with no primer. If the screed is very porous or dusty then a consolidating primer might not do any harm. Would only use decoupler if it is heated and natural stone but with 800x800 it's up to you. It can't do any harm but is probably over engineered. If it natural stone then decoupling is essential.
