Discuss Another new Montolit blade.... in the British & UK Tiling Forum area at TilersForums.com.
Another new diamond blade innovation Monty are launching:thumbsup:
Its common knowledge that chipped edges or a bad finish can occur when cutting hard ceramic tiles? Solution: the new Montolit CG diamond wheel!!
Increasingly hard ceramic and porcelain tiles with uneven or irregular surfaces are definitely giving the tile layer a difficult time when cutting them into beautiful creative shapes and innovative patterns that are being demanded by the customer of today!!
These clients require such perfection in the finish that it is really difficult for the tile layer to achieve the desired effect without having a complicated array of specific tiling tools, plus a good deal of experience!!
For wet or dry cutting such hard tiles as these Montolit has created a new continuous rim diamond blade called Progres CG.
Thanks to the particular mixture of diamond and metal within the cutting crown, Montolit have developed such an innovative blade that the cutting operation is very fast and very precise in terms of aesthetics because the risk of chipping hard tiles has been greatly reduced.
Today the Montolit CG Diamond Blade represents the top of the range as regards diamond blades designed for cutting Gres Porcelain.
These blades are now readily available in 115 and 125 mm diameters.
Reply to Another new Montolit blade.... in the British & UK Tiling Forum area at TilersForums.com
Hi all need a new cutter disc for my small grinder is the montolit txh115 superior to ATS turbo...
Hello lads It was just over 3 years that I have been using my Dewalt tile saw when it got...
Hi guys. A few years ago i bought cheap tile cutter from local store. Now i found out that it...
13K
Cut any shape INSIDE a tile with the brand new PORSABLADE innovation. It's not just a...
8K
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
