Another Question about hardiebacker
I glue and screw Hardie using Mapei Keraquick and latex plus. Just my way, but it seems to work.:thumbsup:
glue and screw with Benfer leaderflex, like you phil it works well for me.
never used a tube glue as i feel it wont fill the voids/create a laminate effect.
Thats exactly how aqua panel by Brittish Gypsum recommend fixing there backer board mate! (flexi adhesive) Nothing wrong with that whatsoever in my opinion.
Never used before but got a job next week. Brand new house, bathroom floor. The floor currently has 22mm chipboard down, and removing it is not an option. It is inly a small area and is very very sold - no detectable bounce/deflection anywhere.
What would be the best option
1) 6 mm hardibacker board - if so, does it HAVE to be stuck down with adhesive as well as screws? Seems like overkill to me.
2) 12 mm ply. I've used ply many any times in the past, never any issues.
WHat would be best?
Why question it now then...?
6mm boards with adhesive and screws, make sure the addy is flexi! Its like tiling with big tiles and you wouldn't tile without any adhesive! 🙂
OK guys - you lost me here. I thought that the whole point of screwing Hardibacker 250 on chipboard was because tile adhesive causes the chipboard to warp? So why use flexible or any other type of tile adhesive? I could understand gripfix or no more nails, but tile adhesive??
you only need to use adh under 6mm cement sheet to fill in voids or bowed floorboards so that cement sheet stays flat the screws hold it in place any cement flex adh will do
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
