Ascot
Hello.....hoping some of you can offer some advice.
I am in the process of tiling my bathroom. I have installed the shower tray in the corner of the room (brick/plaster walls) and built a fin wall on the third side. I have, however, used 18mm plywood to sheet out the fin wall. I realise now that i should have used a tile backer but now that its done, i can't get the ply off because its built right up to the shower tray.
I am using 250x380mm marazzi minimal tiles and Mapei Keraflex S1 adhesive.
I spoke to the technical guy at Mapei to see if i needed to prime the ply first and he said that it would not need primed but needs to be WBP at least. I'm not sure that it is, its just from B&Q. He said if it is not WBP or marine grade then it would need replaced (or sheeted over which i can't do because it would ruin my tile layout for the front face of the fin wall).
What would you do in this situation? If it's not WBP would priming it help? (He wouldn't comment on that). Or do you think this is totally necessary to take it all apart again? Is there any other treatment that might work? Or do i just tile away and hope for the best?!!
(I have already tiled the back wall of the enclosure.)
Obviously I dont want the tiles to fall off, but rebuilding the fin wall and box that is attached to the other side is A LOT of work to undo!
Hope some one can advise.
