Discuss Anti-crack matting?? Why? in the DIY Tiling Forum area at TilersForums.com.
I’m about to tile a small bathroom floor with 20cm porcelain tiles on a very solid floor overlaid with 12mm WBP using Mapei Keraquick with latex. I’ve used this before and 10 years on still good, no cracks etc. But the local tile supplier says I should use anti-crack matting. I always thought you should over-ply to eliminate movement, yet what he showed me would appear to allow movement??? Am I missing something here and why is he saying this is necessary? I’d be grateful if someone could explain the tech aspects and exactly how this works?
Idk for sure, but I am reading this article about it.
are they suggesting anti crack matting over the substrate, or on top of the over plyed floor?
Over the ply... but I spoke with Mapei technical and they said Keraflex would be fine directly onto the ply, so thats what we've gone with.
Reply to Anti-crack matting?? Why? in the DIY Tiling Forum area at TilersForums.com
PVA V PRIMERS – WHy you should never use PVA Glue when Wall Tiling Don’t listen to that idiot...
gamer1
Hi, Would you use Durabase matting over Hardie 6mm floor? Im not 100% happy with the ply floor...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
Barrow-in-Furness
What member type are you?
  1. Contractor
  2. Bathroom Fitter
  3. Kitchen Fitter
Business Name
Misterfix
DIY Tiling Forum
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
