Stewart
Those tiles cut a treat as I've put them up a few times. They are quite light too for the size of tile, but would check the weight so not to exceed limit for skimmed wall once you factor in addy and grout. I normally use a 10mm trowel for that tile and always back-skim using a standard or rapid-set SPF addy. Also be careful with the edges, as they chip quite easily.
