Discuss Anyone Got A Solution To This Problem? in the Canada Tile Advice area at TilersForums.com.
gooty
whilst doing the sums for laying my tiles, i made a slight mistake.
basically, one line of tiles that run beneath the lower face of the window bottom are approx 1mm too low. the metal window edging that i want to use kind of rocks like a seesaw on the render/metal beading beneath.
all i can think of doing is either:
a) use a grout line to make up the difference between tile and trim before laying the inside window tiles :(
b) cut the part of the trim that goes underneath the inside window tiles so that the trim can sit lower, but i guess it will become loose over time :(
c) hammer/chisel out the new render/metal beading so that its low enough to make up the difference with the tiles/trim :(
Can anyone think of a better idea?
MW Smith Ceramics
When I'm tiling round a window I'll always take the tile just past the reveals usually to any high spots then rule off with rapid set adhesive to make perfect especially if using metal trim.......sounds to me like you haven't come to the highest spot of the the window sill and then ruled off the rest of the sill, if the trim rocking then that's not good mate, if it is a 1mm gap all the way along then no problem just grout it in in.......:thumbsup:
Reply to Anyone Got A Solution To This Problem? in the Canada Tile Advice area at TilersForums.com
Hello, after watching so many instructional videos and planing, I just can't understand how to...
Hi, new to forum and first post, after some advice. Recently had the chamber of my fireplace...
I'm looking for solid answer or opinion. We had some windows removed on an exterior wall and...
    Votes: 7 5.2%
    Votes: 13 9.6%
    Votes: 8 5.9%
    Votes: 39 28.9%
    Votes: 16 11.9%
    Votes: 33 24.4%
    Votes: 3 2.2%
    Votes: 2 1.5%
    Votes: 20 14.8%
    Votes: 18 13.3%
    Votes: 15 11.1%
    Votes: 7 5.2%
    Votes: 3 2.2%
    Votes: 3 2.2%
