Cement and plaster don't mix. It creates a chemical reaction. So as long as you prime it, to create a barrier, and tile it, it's fine.
Or used a tubbed / dispersion adhesive and go straight over it, as that doesn't have cement in.
Don't buy the adhesive and grout all in one though.
will this stuff do http://www.NoLinksToThis/p/mapei-wat...-1-5kg/64982?dclid=CKars_Se69ICFYxFGwodw3oGng
If not, what should I buy, can you link me to a product that I can use? thanks
Need to do it as quickly as possible cos i cannot use my kitchen without tiles.
I already put the weak primer on, then before it dried I put a neat coat on, granfix.
I just need to know what product to buy, cos I have never tiled before and I don't know if i can use my kitchen without the tiles. thanks
Is there a tub of ready mixed stuff that I can use. if so, could you post a link to one i can order as i am housebound. Can I use my kitchen in the meantime?
what type of chemical reaction does it do, is it explosive, or can it ruin the plaster or rot the timber underneath?
