aqua panal onto breezeblocks
strippin a shower area tomorrow, and replacing plaster board with aqua panal, at the moment the plaster board is dot and dabbed, what would be the best way to put the aqua panal onto the wall?? any advice would be appreciated:huh2:
prime the breeze blocks with sbr bond then spread them up with spf rapid adhesive dot and dab the aqua panel with spf rapid if you put lots af small dots close together then tap it home you will get a good coverage and you will be fine
Once the spf has gone off I would put a couple of fixings thru the cement board into the breeze, Just a secondry precaution
have you ever tried to take a tile off of aqua panel ?it pulls the panel apart so i dont think you need a mechanical fixing but if you feel you need it go for it
I 'll be honest I've never glued a cement board to a wall and never will, If the worry is that water will ingress to the walls then tanking should be used even on plasterboard
Tags Tags
usa
poynton phil,
poynton phil,
poynton phil,
poynton phil,
