Discuss Aquapanel / Hardibacker 60mm screw into Metal Studs in the DIY Tiling Forum area at TilersForums.com.
darry
Hi, I want to replace the Plasterboard around the shower with Aquapanel or Hardibacker. One wall requires 60mm screws (as it has double plasterboard to pad out to tray), and they need to go into metal studs. Is there an alternative to Aquapanel or Hardibacker screws that are long enough and won't rust? Posts I've searched are for timber studs only. Thanks
Kyle Knowles
1,108
Widnes
Thanks Localtiler for the info. If I get the waterproof boards I still have the issue of needing long fixings 50mm-60mm on 1 wall due to double thickness. Should I just use 50mm Stainless Steel Self Tapping screw, to go into metal studs?
Yeah standard stainless self tapping screws will be fine u need to buy wedi washers aswell so the fixings don't pull straight through the board as u drive them in
Reply to Aquapanel / Hardibacker 60mm screw into Metal Studs in the DIY Tiling Forum area at TilersForums.com
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
This is a proper newbie question. I've tried to find the answer already provided on the forum...
Hi all, I'm redoing my bathroom that I did 15 odd years ago. Before it was tiled with 20x20...
DIY Tiling Advice Forum
Trending DIY Tiling Forum Threads
Wetroom and Tanking Systems Popular
My 1st Job
DIY Tiling Forum
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
