Guest viewing is limited
Discuss armeg rubbish? in the UK Tiling Forum area at TilersForums.com.
philg43
i spent over £200 for a hole cutting kit for armeg about 18months ago i am really disappointed with it the arbour has fallen apart and the diamond shaped tungsten pilot drill bits are expensive and dont last long in my opinion
Hi Gary, sorry for the problems you have encountered.
Which part of your arbour has fallen apart ?
How many holes are you getting out of the tungsten carbide bits?
Feel free to PM me if you prefer.
Phil.
philg43
Used their diamond shaped drill once.............that was once................:lol:
Hi Fred,
The operating guidelines must be followed for the carbide bits otherwise failure can occur. They are:-
a) the speed must be 700-900 r.pm. We have had drill bits sent back that have heavy scoring around the shanks. This indicates that the chuck of the power tool has not been tightened correctly and so speed of operation cannot be guaranteed.
b) a constant flow of water must be applied to the drill tip at all times during drilling. This is not massive volumes of water, a fine jet is sufficient from a pressure sprayer.
c) in the hardest grades of porcelain, a fairly firm pressure must be applied to keep the drill bit progressing through the tile. If the drill bit is allowed to "dwell" in the tile, not making progress, then wear can occur. If it is taking you more than a few seconds to produce a hole then it is invariably due to the fact that not enough pressure is being applied.
Best regards,
Phil.
TilingLogistics
Hi Fred,
Best regards,
Phil.
I think in all fairness Phil when you want to drill a hole thats it. Setting speeds on drills etc? How many fixers has one of those then? I carry a system with me but I also use it more than most and I am regularly asked to drill Granite, Marble & Porcelain. When you see these systems at shows it is conveyed to the potential purchaser just how easy it is to drill holes.!!! At the end of the day I think most people want simplicity.
Kev
Reply to armeg rubbish? in the UK Tiling Forum area at TilersForums.com
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
Exited to report we are relaunching our box set change. What's new and why the change? We only...
Deleted member 1779
Drilling a hole into a Belle bath. Fitting Victorian taps. Drill steel baths. Project fitting...
5K
Deleted member 1779
The guys at Hansgrohe have made life great for clients but difficult for installers. There is...
5K
Deleted member 1779
armeg rubbish?
Tags
usa
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
