Discuss armeg rubbish? in the British & UK Tiling Forum area at TilersForums.com.
F
Fred
Hi Fred,
The operating guidelines must be followed for the carbide bits otherwise failure can occur. They are:-
a) the speed must be 700-900 r.pm. We have had drill bits sent back that have heavy scoring around the shanks. This indicates that the chuck of the power tool has not been tightened correctly and so speed of operation cannot be guaranteed.
b) a constant flow of water must be applied to the drill tip at all times during drilling. This is not massive volumes of water, a fine jet is sufficient from a pressure sprayer.
c) in the hardest grades of porcelain, a fairly firm pressure must be applied to keep the drill bit progressing through the tile. If the drill bit is allowed to "dwell" in the tile, not making progress, then wear can occur. If it is taking you more than a few seconds to produce a hole then it is invariably due to the fact that not enough pressure is being applied.
Best regards,
Phil.
Thanks for that reply phil. I believe I did all that. It was on porclian tiles, 10mm drill as I recall. It only lasted 10 drills, is that correct?
philg43
Hi Fred,
Sorry about the delay, been busy with an exhibition and one of those weekend thingys.:yes:
I usually quote worst case scenario in the hardest grades of porcelain. If used correctly you should achieve 15 - 20 holes. This could rise to over 50 depending on the grade and thickness of the tile.
The most common problem people have is when they don't apply enough pressure whilst drilling. It sounds a bit backwards but you can wear these drill bits by not pressing on hard enough. They must be allowed to make progress, if they "dwell" wear will occur.
The first holes should be produced in seconds. If this doesn't happen, it's usually down to incorrect speed or insufficient pressure.
If you still have the drill bit, please feel free to send it to me, I will take a look and see if I can shed any light on it. PM me for a return address if you like.
Phil.
Deleted member 1779
When you use a 365drills product you get durability from diamonds that encrust each Porsadrill holesaw. Even our 6mm and 8mm holesaws have diamonds.
Above shows the begining of an 8mm hole being formed by diamonds with Porsadrill
If you contrast and compare A and B below.
A: Was drilled by a competitor product using arrow tip cardbide drills of 8mm.
B: Was drilled by a 365Drills 8mm diamond Porsadrill holesaw.
You can see that the arrow tip has "swathed" at the tile from an inner point causing a distortion of the hole as it roughly "beats" the edges to widen the hole in an ever increasing diameter.
In contrast 365drills bore a perfect barrel into the hard material. It does this by slowly grinding away at the material so that there are no chips or scratches.
Drilling multiple holes with a single drill bit is a routine task for Porsadrill
Reply to armeg rubbish? in the British & UK Tiling Forum area at TilersForums.com
Q
    • Winner
    • Informative
So I was recently asked to fit some 3m x 1.5m 6mm thin porcelain in a new tile showroom. Mapei &...
8K
Qwerty
Q
Exited to report we are relaunching our box set change. What's new and why the change? We only...
Deleted member 1779
Drilling a hole into a Belle bath. Fitting Victorian taps. Drill steel baths. Project fitting...
5K
Deleted member 1779
The guys at Hansgrohe have made life great for clients but difficult for installers. There is...
5K
Deleted member 1779
armeg rubbish?
Tags
usa
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
