J Sid
got a new blade from Alan @ATSDiamondTools this week to cut some 20mm porcelain .
put it in a Rubi TC 180 and cut about 80 ln mts and was very impressed. Very clean, chip free cut in one pass.
Discuss ats Diamond Tools 20mm porcelain blade in the Tiling Tools area at TilersForums.com.
Good to know Julian, so you got the Rubi then? ....wet or dry cut?View attachment 104776
Is this new range of blades inspired by the ones that were brought to light on here a couple of months ago ? They look like they are the same style. I know Alan was testing some out.
Great! Is there any reduction in lifespan with this blade compared to the Turbo blade for example or turbo x
I only ask as I had to discard one pretty quickly. Granted it wasn't one of your blades, but the other one as posted on here
good question,
you push it away from yourself, so the blade is cutting down. That blade did give an excellent clear edge on the porcelain.
Reply to ats Diamond Tools 20mm porcelain blade in the Tiling Tools area at TilersForums.com
