Tiling Tool Suppliers
Discuss Ats porcelain blade issue in the Tiling Tools area at TilersForums.com.
Ive had two go like this before I do a lot of mitres seems to happen when doing them but wouldn’t use anything else top blades
Bill
Tom is quite correct, they’re not designed for mitres, some even print a symbol on them to denote that.
Using these blades at an angle stresses the blade, they’re designed for straight cutting only.
The tendency from the user is to inadvertently push the blade up in to the material as well as forwards, this effectively bends the blade as it’s used.
Nearly everyone I know has suffered that kind of damage
Any profiling discs you recommend? The montolit one is decent but a bit pricey
Ats carry a very good profiling blade, that works with porcelain.
115mm Electroplated Diamond Grinding Disc - ATS Diamond Tools - https://www.atsdiamondtools.co.uk/product/115mm-electroplated-diamond-grinding-disc/
The STL blade you mention can be sourced from our sponsor @Pro Tiler Tools
Just be aware they are very material specific and are best used for profiling and not actually cutting as their literature suggests. But that’s in my opinion.
(And I have lots of them!:))
Rubi have also just brought out a half decent profiling blade also.
Can’t remember what it’s called but it’s quite distinct with its golden/bronze colour. It’s also smaller than most.
Reply to Ats porcelain blade issue in the Tiling Tools area at TilersForums.com
  • Sticky
Hi! Hoping for some advice on fixing this efflorescence. Only have this issue in the shower...
This is interesting if you are saying that a builder/tiler has to pay to take away and dispose...
Hi I have just had my wet room tiled and after one use the cream coloured grout has gone black...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
Tiling Tool Popular Threads
Cranbrook
Pontypridd, South Wales
Business Name
Cranbrook Construction
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
