Gross Loydman
I'm going to be boarding my bathroom with NMP ready for tiling. I've taken the walls back to breeze block but am unsure which adhesive to use. The NMP adhesive seems really expensive so was going to use a 'single part flexi rapid set adhesive' as specified on the NMP website. Does anyone have a particular recommendation, and ideally a link to the best stuff to use?
I'm going to be using ceramic tiles, not porcelain, but want to make absolutely sure that the boards are firmly fixed to the walls (I have nightmares of the boards coming away from the walls and having to re-do everything). Do I need to mechanically fix, and if so how?!?! It looks like the NMP would be pretty difficult to countersink...
Thanks in advance.
GL
PS The NMP guy recommended PVA'ing the wall before fixing the boards... I know that PVA'ing a substrate that you're going to tile onto is a no-no, but what about breeze blocks prior to NMP'ing?
Thanks in advance.
GL
