Discuss Back Buttering in the UK Tiling Forum area at TilersForums.com.
my concern there is the potential for trapping air pockets Andrew and therefore not getting a solid bed.I tired a slightly different method today to my normal back buttering, after watching another tiler use it and discussing it with him. Notched floor and back of tiles (600 ceasar stone)8mm on floor 4mm on tile and cross bonded, the sub floor was slightly out and this method made light of it.
Also most adhesives have max deph of about 5 mm as was said don't cross bond no air pockets solid bedI tired a slightly different method today to my normal back buttering, after watching another tiler use it and discussing it with him. Notched floor and back of tiles (600 ceasar stone)8mm on floor 4mm on tile and cross bonded, the sub floor was slightly out and this method made light of it.
What adhesive was that?It was meant 8mm 4mm on tile 4mm on floor. And adhesive was good to 12mm, as i said the floor was a little out and the extra few mm got me over it.
regarding the air pockets never gave it a thought, I think I shall be returning to my tried and tested!
really,5mm,im surprised,as not every floor is completely flat,and we should always use a 10mm trowel or more on floors
No need for back buttering when you use dot & dabs fails every time
get away with ya,never :lol:,10mm trowel used at an angle will give approx 8mm bed, press your tile down firmly and there's your 5mm
tony,he is taking the gypsy's mate:devil: back butter every tile , wall or floor, all the time. gives much better bond. plus if you do 10mm natural stone (white marble etc) in wet rooms, when walls/floor get wet, dots will show.
just would of thought most adhesives would be able to do thicker than 5mm,aint a right lot really in the grand scheme of things
Reply to Back Buttering in the UK Tiling Forum area at TilersForums.com
