Discuss backer boards in the British & UK Tiling Forum area at TilersForums.com.
baht'at
Hi All,
I have a floor to quote for 36m2 in all and intend using 6mm backer boards on all of it but 12m2 is old floor boards and the rest is New chipboard.
The old floor boards are bowed and intend to apply addy under the backer boards in this area but on the new chip board will it also require addy underneath it ??
baht'at
Thanks Grumpy,
I might not have explained very clearly its not the floor that has bowed but the floorboards them selves . the tounge and grove part has curled upwards slightly creating a slight concave profile with the edges.
As its not advisable to tile straight on to the TREATED chipboard floor as I have read the addy will not bond will it not be the same under backer boards ??
grumpygrouter
I knew what you were talking about with the bowing mate, I would still consider using a leveller first because as you screw down you boards onto the wet addy, it may get pulled into the curve of the board. You need the adhesive bed under all the boards to avoid leaving voids under the backerboard.
This is what is recommended by James Hardie's literature.:thumbsup:
Grumpy
Reply to backer boards in the British & UK Tiling Forum area at TilersForums.com
We had a wet room fitted by a large company. We have issues with a few large steps where the...
backer boards
    Votes: 9 5.3%
    Votes: 17 10.0%
    Votes: 12 7.1%
    Votes: 49 28.8%
    Votes: 21 12.4%
    Votes: 40 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 23 13.5%
    Votes: 19 11.2%
    Votes: 17 10.0%
    Votes: 8 4.7%
    Votes: 5 2.9%
