Discuss background for tiling a shower in the UK Tiling Forum area at TilersForums.com.
Thank you for clearing that up Dock
got to disagree, water can pass through hardie backer boards.Marko56,
I have just had a scan through the messages, here are some pointers......
1 - you want to plasterboard and then tank?
2 - you want to load heavy tiles
3 - you looked at backer boards but expensive.
Ok.. to the first one you can just use HardieBacker as 1 its impervious to water so won't breakdown like the plasterboard and 2 you don't need to tank the product.
HardieBacker can hold much more weight than plasterbaord. Our literature states it can hold 50kg m2, we have since done some new testing which has resulted in over 80m2 using a good adhesive.
HardieBacker is not expensive, if you use plasterboard and then tank that will cost more! plus you need the tanking to dry for 24 hours before tiling!
Hope this helps.
Reply to background for tiling a shower in the UK Tiling Forum area at TilersForums.com
