Discuss Backing board compression in the Canada Tile Advice area at TilersForums.com.
Anna Rack
Got some 6mm backing boards on which I hope to lay some 30mm or maybe smaller mosaic tiles.
The board feels fairly compressible (by hand at least) and was wondering if sinkage with very small tiles might be an issue.
I phoned the manufacturer (Prowarm) and they seemed to think it would be fine although weren't 100%.
Anybody had an issues?
Thanks in advance.
Anna Rack
Thanks. According the manufacturer the boards have a 30 t/m2 compression strength.
If my maths is correct this means a 30mm square tile would take 27kg. Does this sound adequate?
If I went to 50mm tiles that would increase to 75kg which sounds more than adequate bearing in mind (excuse the pun) I wouldn't be wearing high heels in the toilet?!
Found this description for a board which has the same specification:
PCS Wetfloors and Tile Backer Boards are made from extruded foam (agglomerated styrene particles). As a result the density weight loading is 30 tons per sq metre.
This may sound a lot, but gives us the confidence to permit use of tiny (25mm x 25mm) mosaic tiling. The maximum point load per tile is therefore 18.7kg per 25mm x 25mm tile and customers can have total peace of mind that the tile will not sink into the board.
Reply to Backing board compression in the Canada Tile Advice area at TilersForums.com
Hi folks - first post here but a long time reader, so hello! :smile5: Now onto my question -...
8K
I
Hi all, I am after a bit of advice after becoming conbfised over many different answers from...
7K
lizzardtong
L
I
Good evening all, Has anybody used the mosaic boards that you can stick to the back of the...
ifindoubtgrout
I
Hello all, Right...the Wife and I have just bought a right old project so funds are low, so I...
11K
p4ulo
Hi, Looking for some advice with respect to installing underfloor heating and tiled floor into...
10K
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
