Badly cracked limestone - can I replace individually with decoupling
I totally agree with you.
I don’t envy you guys because to do the job PROPERLY is expensive.
Proper suitable sub floor
Correct drying technique
Quality adhesives/grouts
Decoupling membrane
Quality sealant
Skilled fitting
It becomes very apparent that the tiles are a small fraction of the actual overall cost...
This post should be pinned to the top of the page....
'I need some help'
So does anyone think that I might be able to replace a few tiles and 'individually' decouple them to stop the subfloor crack migrating to the tile?
Anyone ever tried it?
Yes me, in my own house I tiled the bathroom floor in 2012 and like a fool I had a hardiebacker join 20mm from a chipboard join and had a fracture across two tiles at the side of the shower tray. I lived with it for a year but everytime I walked over the crack it annoyed the hell out of me.
I smashed up the tiles carefully and got the hardie up and bonded down a piece of leftover Ditra mat and put the tiles back.
I even had some cream grout left over from 7 years ago and I thought I would try it (never in a customers house) and it worked and set perfectly.
I had two 600x600 tiles crack in a new build 6 months after install, customer wouldn't pay for mat on origanal install, took hours to lift them, taking back to base, used mapei 1mm mat and installed new tiles. No probs 6 months later. You have to be so careful near the edge of the rest of the tiles.
Yes, I gaffer taped the edges and usding a 7mm SDS bit I machine gunned the tiles keeping away from edges its a right painstaking slog.
I’m planning to take up a particularly badly cracked limestone tile (600 x 300). I will remove all adhesive and try Ditra matting as I believe there is enough depth free as the adhesive was particularly thick in this area to keep the level.
What flexible adhesive & grout would you recommend (screed has wet UFH) ?
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
