Discuss BAL adhesive in the British & UK Tiling Forum area at TilersForums.com.
grumpygrouter
Check BS standards for overlayes when using single part adhesives its 15mm unless using tile backerboard then you can use 10mm:yes:
Strange that, as backer board doesn't really add any strength to the floor, just gives a better surface for the addy to grab on to and is more stable heat and moisture wise.
grumpygrouter
Don't ever recall seeing 15mm ply personally, only ever 4, 6, 9, 12, 18, 22 and 25.
Again, this brings up the discussion of the reason for boarding out a floor. Is it to strengthen a floor or to just give a nice surface to tile onto?
BAL powerspec gives information on materials "by the book" to cover their own warranties. In the real world, many chipboard floors are absolutely solid and require no further strengthening. In this case 6mm backerboard is fine to protect the chipboard from moisture induced movement. Appropriate adhesives do a fine job if the situation is suitable and not require any boarding out. My prefered straight to timber/board is Ardex 7001. It is considerably cheaper than Fast Flex.
All just my opinion obviously.
grumpygrouter
Tileform, I (used) nto be able to get 7001 for about £26. I did a 7m2 entrance hall on my last job with 1 bag!
The beauty of it is that you mix it quite thin - it will run off the trowel - and assuming your floor is flat you can use a 6mm trowel for tiles up to 300x300. Because it is thin, you get 100% coverage much more easily.
Brilliant stuff IMO.
Prime with Ardex P51 (neat) first.
grumpygrouter
Much appreciated
Whats your approximate price for 5001 or X7G plus?
Never bought it up here mate so couldn't tell you. My supplier for ardex is no longer taking it in.:furious3:
Last time I bought X7G plus (i don't particularly like it , by the way) it was £13.78 plus vat from CTD. I have never used 5001.
Reply to BAL adhesive in the British & UK Tiling Forum area at TilersForums.com
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
BAL adhesive
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
