Discuss Bal Fastflex Drying time in the British & UK Tiling Forum area at TilersForums.com.
coco3107
Hi guys been reading the forum for a couple of weeks, never realised there was so much to tiling but it has been a great learning curve thanks!
I am doing a bathroom in a flat I own which is chipboad on joists screwed down, then as you guys seem to recomend, 12mm wbp ply at 100mm centres screwed and glued, then the primer supplied with the underfloor heating wire screeded in using 2 part fastlex as recommended by Bal technical. The problem is I mixed it as per the instructions and laid it with a flat trowel to screed the wire in, but 5 hours later it is still not dry? Should I be worrying? Thanks in advance Colin.
:huh2:
F
Fekin
Hi thanks for the response, Why not? it was recomended by Bal technical and as a newbie I belived him, where did I go wrong and what is the fix? regards Colin.
As I said, I have never used fastflex so I couldn't say from any experiance how long it took to set.
If it's only been 5 hours I wouldn't worry, leave it over night and see what it's like then... should be set most probably.
Reply to Bal Fastflex Drying time in the British & UK Tiling Forum area at TilersForums.com
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hi all, I have a fully cured sand cement screed that howeever needed proper levelling and prep...
Hi everyone, I'm getting towards the end of a major renovation that has taken 4+ years so don't...
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
