Discuss BAL Mosaic Fix in the UK Tiling Forum area at TilersForums.com.
DHTiling
bal mosiac fix is.....
A bright white, non-slip, water and frost-resistant, cementitious wall and floor tile adhesive specially formulated for fixing mosaic tiles including glass mosaics. It is also suitable for fixing ceramic wall and floor tiles, metal or glass tiles, marble, terrazzo, and natural stone in interior and exterior locations. Suitable for use in swimming pools. Can be used on most surfaces including MDF (in internal dry areas).
bal spf is..........
A flexible, non-slip, water-resistant and frost-resistant wall and floor tile adhesive, especially suitable for fixing tiles, including fully vitirfied and porcelain tiles to low porosity backgrounds/bases. Suitable for use on concrete/brick/block walling, cement:sand rendering, plaster, plasterboard, cement sheets, tile backer boards, concrete bases, cement:sand screeds, plywood overlay, ceramic/quarry tile/terrazzo/hard natural stone, vinyl tiles/sheet bases, mastic asphalt. Conforms to BS EN 12004, Type C, Class 2T.
hope this helps......dave.....
Reply to BAL Mosaic Fix in the UK Tiling Forum area at TilersForums.com
Make sure to mark a post as a solution for better transparency.
