I
Discuss BAL SBR & APD. Confusion in the UK Tiling Forum area at TilersForums.com.
Thanks dave...lolI use BAL APD to prime plaster before using bagged adhesive, but was wondering what is BAL SDR used for? Is it a similar product?
Cheers
Yes it is. You might want to check the weight of your tiles though before you start. 20kg/m2 for plaster skim!is bal apd suitable for use on skim walls before fixing 400x400mm porcelain tiles to it?
May be wise to check the weight. Don't forget to add on the weight of the addy and grout into your calculation. Dont want them falling off on anybody. if 6 tiles approaches 15kg, I would be wary.oh, the tiles are heavy!! 8.5 mm thick 400x400mm! i'm due to start at 11 am tomorrow!
Reply to BAL SBR & APD. Confusion in the UK Tiling Forum area at TilersForums.com
