Discuss BAL WP1 Shower kit in the UK Tiling Forum area at TilersForums.com.
trammel
Evening all,
I have had a problem with a BAL WP1 shower kit. The shower will be fitted in a corner, one wall bonding coat and skimmed, the other plasterboard and skimmed. Both walls left for five weeks to dry out.
I sanded both walls and then used a stiff brush to remove any surface dust to get a key. Applied APD as per instructions, left to dry then put on two coats of membrane using the polyester tape as per instructions.
However when I removed the masking tape where the shower enclosure will meet a painted wall, the coating peeled of in one large piece(4 square metres). The only place it has adherered is where coating meets the paint mist coat.
Am I a muppet and missed something?.:huh2:
Any advice welcome
F
frogeye
hmmmmmmmmmmm
I had a similar - yet much smaller problem - when I used the same kit. I tiled over plaster - used the supplied primer as directed - applied 2 coats and when ready to tile I accidentally snagged the surface - a blister the size of a 50p piece appeared. Not knowing the material I reapplied and proceeded as normal - nothing has fell off to date - but it always bugged me that the bond with the plaster wasn't what I thought it should be. Oh and no dust problems either
frogeye
F
frogeye
It was a few months since I used it and the box is in the garage and as I am into my 2nd g & T and its cold and dark, that is where it will stay, BUT, I am sure I followed the instructions to the letter - no, I will go further - I DID follow the instructions.
I will be doing a shower enclosure very soon and using what's left so I will report back. If I get the stud wall and plasterboard done I hope to make a start before Monday - any later than that and I will be in aus for a well earned holiday. Tasmania here we come!!!!!!!!!!
frogeye
Reply to BAL WP1 Shower kit in the UK Tiling Forum area at TilersForums.com
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Hi, I am a keen DIYer and have chosen an Impey Aqua Dec 4 and waterguard tanking kit. The Aqua...
Hi I’m fitting a Nova Frameless 1000 x 800 Sliding Door Shower Enclosure with a low profile...
BAL WP1 Shower kit
