Discuss Balcony tiling in the UK Tiling Forum area at TilersForums.com.
K
kaharrison9
Evening All.
Initially looking into quoting for an exposed outside balcony.
The outer tiles are cracked and others are loose.
The concrete base i imaging is sodden as moss and black mould is in the cracks.
Has anybody any pointers on drying external concrete in our climate and also would it be better to use an epoxy grout rather than cement
Many Thanks
Kevin
bugs183
Find out exactly what is underneath, it may not be concrete, more likely Ashphelt.
You'd be better off covering the balcony completely, striiping the tiles and let the whole thing dry naturally.
Only tile it if it can be made totally weather proof, finding suitable weather windows in this country is impossible, if anty water gets into the adhesive or grout as its curing it will ruin the job.
bugs183
I'd spec the job as highly as possible so yes i'd use epoxy, or at least a really good quality flexible grout.
Go on to the Schluter website and look at 'Ditra Drain'. I dunno if you're familiar with DitraMat, but this alows any water that get through the grout/and adhesive and allows it to run away underneath the tiles, so stopping any freeze/thaw problems going on under the tiles.
Reply to Balcony tiling in the UK Tiling Forum area at TilersForums.com
I recently got several loose/hollow tiles rebonded on my bathroom floor. Having left with...
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hello! Council (freeholder) gave retiled my balcony as they had to fix the one above me so...
7K
Hey guys, first time poster so be kind! I had some porcelain tiles fitted in 2012, in the...
9K
WetSaw
Balcony tiling
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
