Discuss Basalt Recommendations in the UK Tiling Forum area at TilersForums.com.
basaltlover
Hi Everyone,
New to the forum but I love perusing the posts and learning new tricks.
In two days I'll be tiling my shower with 4 x 12 honed basalt tiles that are 3/8" thick. I've received a couple of different recommendations on the best application method. Best I can tell people seem to prefer back buttering with a straight edge trowel and using a 3/16 v notch on the wall/floor. Does this seem right with the gurus on this forum?
I plan to use an impregnator but again people seem divided. Should I apply before we tile or once the tiles are on the wall?
I know its crazy but I'm going to attempt a 1/16 grout line (at least at first). Any recommendations on grout?
Any other recommendations for basalt would be welcome since this is my first time working with the stone and its in my own home so my wife would appreciate it if it looked nice :)
tfs
fit the tiles by trowelling to wall only at first, lifting them again to see if you achieve good coverage without back buttering, if not, then back butter. Be sure to lift every few tiles to contstanly check that you are getting a good bond.
I have fitted large format basalt and sealed after but for peice of mind it is best to seal before and then after!
Reply to Basalt Recommendations in the UK Tiling Forum area at TilersForums.com
After annoying the guys in my local CTD for about an hour looking at samples and agonising on...
Tags
usa
