Discuss Base for porcelain at back of garden? in the Australia Tiling Forum area at TilersForums.com.
Robthespoon
Hi, so I want to do some DIY laying of porcelain tiles at the back of my garden. At the moment it's just compacted soil, (area of approx 3 m x 2 m) so I realise I need a few layers before I lay the tiles, but I can't work out what.
Chappy in topps tiles recommended 3 inches of grade 1 gravel, then layer of flexible adhesive, then tiles, but I wasn't entirely sure he was trustworthy!
Any recommendations would be massively appreciated
Rob
SJPurdy
Rob
Definitely not that!
It will be dig out and fill with a well compacted layer of sub base ("hard-core") followed by a concrete base (probably with a blinding layer of sand in between). Then when the concrete is fully cured tile it with a flexible adhesive. You should be able to find the appropriate layer thicknesses in a general building guide if someone else doesn't post them here.
SJPurdy
A Blinding layer of sand not a binding layer. It means that the concrete is decoupled from the underlying base and can contract and expand independently. If it was an indoor base where a damp proof membrane is needed then it also covers the sharp bits of stone to prevent tearing/holing of the membrane.
As for thicknesses, well I'm not a builder but an old DIY book I have suggests: If it is firm ground then it can just be compacted and the concrete layed on it. but looser ground needs stabilising with some hardcore.
For paths 25-50mm hardcore then sand to cover then 75mm concrete.
Drives 75mm hardcore then sand to cover then 100mm concrete.
If I was you I'd do some googling to get some up to date specifications, but of the ones I have given I would treat it as a drive not a path.
Reply to Base for porcelain at back of garden? in the Australia Tiling Forum area at TilersForums.com
hats67 - Yesterday at 11:48 PM Add bookmark #1 Hello guys. I came upon and registered with...
Hello guys. I came upon and registered with this forum while doing some research on decoupling...
5K
Good evening all, I am currently in the process of swapping out decking for a tiled patio. I...
I live in Berkshire, UK, where the soil is clay. My current patio is block paved (laid about 20...
Tilers Forums on FB
