Discuss Bath Pannel in the British & UK Tiling Forum area at TilersForums.com.
F
faithhealer
Careful there Woody, flat panels are bad enough but once you cut the bottom off it will lose all it's rigidity! How is the panel secured? clips? batons?
Cutting wise, some people use a stanley knife but these can slip and go off course (watch your fingers) I use masking tape to mark the line (if it's not straight you can re-do it) then a fine tooth hacksaw blade. (not a junior Hacksaw blade as these bend too easily)
brian c
take your time and use a stanley knife,see how panel fits in before tiling then use the height from the ply 12mm if you are using it minimum ,plus the thickness of the tile and adhesive must be taken into account.Add these heights together and thats what you take off the bath panel.In addition you will probably have to do the same procedure for the door.Let us know how it goes WOODY1.
Reply to Bath Pannel in the British & UK Tiling Forum area at TilersForums.com
There's a video on youtube of a guy templating for large format floor tiles, and I get the...
Bath Pannel
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.1%
    Votes: 21 12.6%
    Votes: 40 24.0%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.2%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
