Discuss Bath Sealing Strip in the UK Tiling Forum area at TilersForums.com.
As long as you can really, if it's very thick silicone 1 maybe even 2 days, if normal size bead overnight is fine
flush with the bath, it is intended to act as a second water barrier incase your primary silicone (the one put on after tiling) fails
Smooth the silicone off level with the bath Minnie, once you have filled the gap get a small glass and half fill with warm water, add a large squirt of washing up liquid, you can smooth the silicone off with your finger dipped in the solution from the glass, you will find that the silicone can be smoothed off without it sticking to your finger, leave the water in the bath until the silicone has dried completely, at least 12 hours.
it doesn't have to be dead flush with the top, if you want to add more you can. As mentioned before this is a back up seal not the primary one
Reply to Bath Sealing Strip in the UK Tiling Forum area at TilersForums.com
