Discuss Bathroom advice, Aquaboard Adhesive? in the Bathroom Tiling Advice area at TilersForums.com.
jubba
Hi guys,
I am a bit of a novice but did a good job on my kitchen floor and wall tiling with some great advice from this forum. :thumbsup:
Just doing my bathroom now so figured this was the place to come.
Just erected a new stud wall and got some aqua-panels from wickes today, which I am going to fit around the shower bath area.
What i need advice on is a good adhesive to use?
This will be used to seal the joints and fix the jointing tape on the aquaboard.
Going to fit ceramic tiles 250 x 400.
I would prefer to use ready mixed adhesive as it will make the job alot easier for me.
Screwfix do : Bal Bluestar?, unibond?, mapegrip d2?, all suitable for showers?
Also the wickes guide recommends fitting the tape to the aquaboards "immediately before tiling" but surley i could do this in advance as long as I just put a thin coat of adhesive on?
You advice appreciated :smilewinkgrin:
Lee
Scott
A good fleixible powderd adhesive is the way to go. ITs a bit of a waste doing all the correct prep to then use the wrong adhesive. I appreciate they say its ok for showers but you soak some of the dried adhesive in water and it softens. You can get a slower setting cement adhesive, its not all rapid set.
Have you got the tape for the joints? I just use normal scrim tape and skim over the joint with tile adhesive
jubba
Thanks for the advice guys,
Just prefered ready mixed as I will be doing the tiling in small stints, so easy to just do a small area then pop the lid back on the tub!
If powdered addy means a proper job then I'll use that, any advice on what to use / where from? Something that has a longer bucket life and dosent go off too quick would be good as I'm not the fastest tiler in the world. :)
Yeah Scottley paid for the proper tape even though it does look the same as the normal stuff!
You think i can fit the all the tape and put the thin layer of adhesive on then let it set before i start tiling?
Scott
If its bonding or undercoat plaster then yes it will need a bit of skim over it. It the rest of the plaster sound? If its a case it looks like its all going to come off you could hack it off and dot and dab plasterboard on it? Or it the sections are large then you could patch the sections using the same method. For the tape just stick it on and skim a bit of addy ovr the top but keep it a thin skim.
Mapei do an extended set adhesive called keraflex maxi, once mixed it has a pot life of around 8 hours. However its more expensive than some of the others. Just mix smaller quantities as you go.
jubba
Just spoke to the plasterer and he suggested that he can just repair the walls with bonding coat, then I tile straight onto it. Is this OK? Will save me a few quid.
The mapei keraflex maxi spec sheet does state "Perfect adherence to all materials normally used in building" ?
The spec for kerafix all sounds good but best price I can find is £28 a bag. Gonna cost a bit to do the whole bathroom!
So my question is are there any alternative adhesives that will be suitable for applying my tiles in my bathroom:
To Aquapanel and applying the tape.
Direct to bare plasterboard
Direct to my (bonded coat) walls?
Decent pot life, 2-3 hrs should be adequate
Lee
Reply to Bathroom advice, Aquaboard Adhesive? in the Bathroom Tiling Advice area at TilersForums.com
I've got an AKW Tuff form shower tray with a waste that is 10mm above the tray when fully...
Unsolved
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
