Bathroom advice, Aquaboard Adhesive?
jubba
Hi guys,
I am a bit of a novice but did a good job on my kitchen floor and wall tiling with some great advice from this forum. :thumbsup:
Just doing my bathroom now so figured this was the place to come.
Just erected a new stud wall and got some aqua-panels from wickes today, which I am going to fit around the shower bath area.
What i need advice on is a good adhesive to use?
This will be used to seal the joints and fix the jointing tape on the aquaboard.
Going to fit ceramic tiles 250 x 400.
I would prefer to use ready mixed adhesive as it will make the job alot easier for me.
Screwfix do : Bal Bluestar?, unibond?, mapegrip d2?, all suitable for showers?
Also the wickes guide recommends fitting the tape to the aquaboards "immediately before tiling" but surley i could do this in advance as long as I just put a thin coat of adhesive on?
You advice appreciated :smilewinkgrin:
Lee
The wall not too bad, pretty solid just some patches /chunks come off, so will need filling with bonding coat and then skimmimg?
The mapei with 8hr pot life sounds good, I will probably get about 4 tiles in fitted in that time 🙂
If its bonding or undercoat plaster then yes it will need a bit of skim over it.
Just spoke to the plasterer and he suggested that he can just repair the walls with bonding coat, then I tile straight onto it. Is this OK? Will save me a few quid.
The mapei keraflex maxi spec sheet does state "Perfect adherence to all materials normally used in building" ?
Mapei do an extended set adhesive called keraflex maxi, once mixed it has a pot life of around 8 hours. However its more expensive than some of the others. Just mix smaller quantities as you go.
The spec for kerafix all sounds good but best price I can find is £28 a bag. Gonna cost a bit to do the whole bathroom!
So my question is are there any alternative adhesives that will be suitable for applying my tiles in my bathroom:
To Aquapanel and applying the tape.
Direct to bare plasterboard
Direct to my (bonded coat) walls?
Decent pot life, 2-3 hrs should be adequate
Lee
Don't forget to prep the skimmed walls with a suitable primer. I normally use MAPEI PrimerG.
+1 with the Keraflex Maxi. Lovely stuff to work with, can mix up a bucket and tile all day long :hurray:
Thanks again.
Please can someone advise on the technical reasons for the need to skim.
Suction of surfaces / absorbtion of the moisture from the adhesive?
Plasterer has been tonight and says that bonding coat finish with PVA'd surface should be a great low suction surface to tile to, which makes sense to me.
What could possibly go wrong? 🙂
Jubba he is soooooo wrong
For starters dont use PVA, as for the bonding read the top of page 4 of this:
broken link removed
Broken Link Removed
Thanks for the info, Read the section about tiling, now even more confused? :mad2:
Seems to contradict itself, States :
"Tiles upto 20kg/m2 can be applied directly to the thistle finish except where the system includes a bonding agent."
(Does thistle finish mean a skimmed finish plaster?)
but then says
"Tiles should not be applied directley to thistle undercoats,"
Also says :
"As the total weight of plaster and tiles applied over a bonding agent is limited to 20kg/m3"
Don't expect the combined weight of the plaster and tiles to be anywhere near 20kg/m3.
Am i reading this all wrong? missing the point?
but then says
Also says :
Thats the only bit you need worry about if your tiles are ok on the weight.
