Y
yabbie
I wasnt planing on tiling my bathroom floor only the walls but i thought i would have a look ive got 4 lays of diffrent types of lino under all that ive got plywood board which looks like its been painted with something black im guessing its some sort of waterproofing. first bit of good luck ive had in ages . What else would i need to do to check that it would be to tile over its all nice and level.
What type of adhesive will i need to get for the floor tiles. They will be the same as the ones i want to put on my wall only the dark colour. they are 310mmx310mm ceramic floor/wall tiles im guessing i will need a flexi adhesive what about grout or can i use the same grout as the walls.
i plan on removing the toilet as i have a valve fitted already to turn off the water. My only worry i have is the toilet not fitting back onto the soil pipe.
And the skirting board is already off as i think it will look nicer.
cheers for any info/tips
