Discuss Bathroom floor upstands in the Bathroom Tiling Advice area at TilersForums.com.
Tresco
Hi All,
I'm shortly tiling a bathroom with a big 'busy' tile, rather than tile all the walls I thought less is more and that I'd just tile one complete wall and the double vanity unit area, I've seen the look in some very expensive Octagon show homes and it's very effective, (and cheaper!).
It does though mean that the walls without tile would get marked when sweeping/mopping etc, so I thought of cutting the floor tile into say 100mm strips and fitting to the bare walls, I'd use a finisher on top of the tile..
In your experience chaps a good idea or public toilet look?
Gazzer
skirting.jpg doesnt show too well on this photo
John Benton
1,138
Leeds
Thanks John it's a Porcelanosa tile bought from an independent, I'll ask the question.
If the independent doesn't stock it, doesn't mean to say they're not available, you could go direct to a Porcelanosa showroom if you have one near.
I would say that 100mm is probably the right height and if you have fixed the tile landscape then you should get 3 pieces from 1 tile with a good cutter :thumbsup: With it being ceramic you will have to trim it.
AliGage
Subscribed
I've done this a few times, 4" or 100mm is about right. I believe i cut this at around 80mm to match the bottom trim of the modular furniture.
I think upstands work really well at times. I wouldn't of usually used white silicone on these tiles, but this bathroom was foor an old aged pensioner and wanted to be able to see the sealant without getting down to it so he could maintain it himself if necessary.
Reply to Bathroom floor upstands in the Bathroom Tiling Advice area at TilersForums.com
We recently completed the (rectified porcelain) floor tile installation in the bathroom and...
6K
First of all, I'm sure this question has been asked a thousand times so apologies in advance! A...
Trying to Get bathroom re tiled, had conflicting advice from a few tilers, I’m a total novice...
5K
Tilers Forums on FB
