Bathroom floor upstands
Tresco
Hi All,
I'm shortly tiling a bathroom with a big 'busy' tile, rather than tile all the walls I thought less is more and that I'd just tile one complete wall and the double vanity unit area, I've seen the look in some very expensive Octagon show homes and it's very effective, (and cheaper!).
It does though mean that the walls without tile would get marked when sweeping/mopping etc, so I thought of cutting the floor tile into say 100mm strips and fitting to the bare walls, I'd use a finisher on top of the tile..
In your experience chaps a good idea or public toilet look?
skirting.jpgdoesnt show too well on this photo
Thanks John it's a Porcelanosa tile bought from an independent, I'll ask the question.
If the independent doesn't stock it, doesn't mean to say they're not available, you could go direct to a Porcelanosa showroom if you have one near.
I would say that 100mm is probably the right height and if you have fixed the tile landscape then you should get 3 pieces from 1 tile with a good cutter :thumbsup: With it being ceramic you will have to trim it.
Yes the 90cm tile will be challenging! see my previous post in the tile cutting forum..
Anyway decided to invest in one of these, it's a doddle according to the youtube video on the tradetiler website! montolit-p63-600.jpg
Yes I too would recommend 100mm, also if they don't do a finished edge a flat chrome trim on top would look nice, a little less offensive than a round one.
I've done this a few times, 4" or 100mm is about right. I believe i cut this at around 80mm to match the bottom trim of the modular furniture.
I think upstands work really well at times. I wouldn't of usually used white Silicon on these tiles, but this bathroom was foor an old aged pensioner and wanted to be able to see the sealant without getting down to it so he could maintain it himself if necessary.
