Discuss Bathroom Floor in the Bathroom Tiling Advice area at TilersForums.com.
ah666
Hi, I have read through various threads here, and I have successfully tiled a couple of bathroom floors however I am about to embark on a new bathroom floor and want to now the ideal method if I was to start from scratch, here is the current scenario
  • The floorboards (chipboard) in our bedroom and ensuite bathroom creak whenever we walk around
  • The bathroom and bedroom are an extension over a double garage
  • I can feel some deflection when I jump up and down on the bathroom floor
Here’s what I am proposing to do :
  • I am going to take up all floor boards in both bathroom and bedroom
  • Install insulation in the void
  • Install some extra timber alongside the joists to improve the rigidity (I have read this will help)
  • Replace the floor in the bedroom with new chipboard
However when it comes to the bathroom as I want to tile and possibly lay underfloor heating (wet if possible) what is the best method ?
I assume I will have to try and improve rigidity as per the bedroom
In the previous two bathrooms I have done I have fixed Hardibacker over the top of the existing chipboard floor (didn’t have deflection issues and followed instructions on here)
But I now have clean sheet of paper, so do I
  • fit chipboard and then hardibacker
  • just use thicker hardibacker
  • use ply and no hardibacker etc.
I don’t really want the bathroom floor to be significantly higher than the bedroom floor so does this rule out underfloor heating ? (as I assume this would go between the floorboards and tiles and not below the floor boards, a novice when it comes to underfloor heating, will get someone in to do it if I go wet, but like to know what I am talking about)
Your thoughts and suggestions gratefully appreciated
Reply to Bathroom Floor in the Bathroom Tiling Advice area at TilersForums.com
Hello, I did some reading here and there, but the opinions seem to diverge at some point and I...
Bathroom Floor
Unsolved
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
