N
ninjanik
Hi all,
Please excuse me if this is not the correct section to post this in...
I'm currently renovating my bathroom in a small back to back terrace 1915 circ. I've already made a few mistakes which thankfully reading this forum I've been able to catch in time (tile weights on plasterboard). Tiles will be 600x300 porcelean and cover the floor, back wall and shower end of the bath, and the sink / counter top area.
I've included some photos to hopefully make more sense of my questions
Questions
1) The framework which will carry a semi recessed sink is to be tiled. Whats the best substrate for this?
(ply and tank, ply and mrpb and tank, ply and cement backer or ply and marmox)
This also applies to the bath which will have a 100mm ledge which the bath will sit on on one side before the bath panel (which will also be tiled)
2) The back wall and shower end of the bath have been / will be batoned to hide a concealed shower / bath filler etc. The false walls will also be insulated to try and reduce sound from next door. One problem is in order to get the bath to fit, and hide the shower pipes I'm having to build stud work which will 'lap' over the shower end of the bath i.e. the board will sit on top of the bath lip.
What should I be using for these walls? (mrpb + paint tanking kit, hardi backer + paint tanking kit, marmox + tanking tape)
3) The floor!!!
Its a 22mm wood floor board (original) on joists. the joists span the entire of upstairs and the bathroom is located at the back of the house, so the floor is basically the first 1.7 metres of the joists. The joists dip in the middle of the house quite badly which means in the bathroom the floor slopes by 15-20mm from the wall to the sink.
The floor stable with minimal deflection, although I would feel happier if I could strengthen it.
Whats the best way to achieve this? Im not too fussed about a step into the bathroom as the landing already has 12mm ply on top before carpet.
Really sorry for the long first post... and really appreciate any advice / guidance
cheers
Nick
Questions
3) The floor!!!
cheers
Nick
