Discuss bathroom tiling in the Bathroom Tiling Advice area at TilersForums.com.
mikit
hello, I am looking for some advice I have brought some slate tiles for my bathroom floor and some ceramic tiles for the walls which are freshly plastered (seen some conflicting advice about that on here), Should I do the walls first or the floor? and do I need to seal the slate before fixing or before grouting?
Many thanks
Mikit
Alan.P
10 cm x 10cm incusive of 3mm spacers
If your not the fastest fixer a tubbed adhesive will do, ( longer pot life ) most of them don't require priming, best to check on the tub when you decide what brand your going to buy. If your confident enough to use a bagged powder adhesive then the wall will need priming, again, depending on brand. If you let us know what you intend on using we can better advise you.
Alan.P
Use acrylic bond not pva to bond your walls. Tubbed adhesive takes longer to dry, get the slow setting bagged stuff and you will be fine.
:thumbsup:
It will only take a day after fixing to dry, there's nothing wrong with using 'some' tubbed gear in bathrooms :thumbsup: I think we're looking at a steady / slow job, not to knock anyone.
Reply to bathroom tiling in the Bathroom Tiling Advice area at TilersForums.com
Im changing a bath to a tray for a friend and the bath was chased into the wall on all 3 sides...
bathroom tiling
Unsolved
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
