robinsoncrusoe
Hello there, everybody...
I'm just, in it getting set up to do my first tiling job!!. I've fully boarded the bathroom, which has got 1 upvc window in it.
I intend to fit a "mosaic style border, approx 300mm down, from the ceiling. there will be no bath... only a shower cubicle etc.
I've decided where to position the tiles, (already obtained, 248mm x 398 mm), have purchased 40kg Mapei super flexible white, 6mm notched trowel, borrowed wet tile cutter....so, now, just need a bit of courage to start !!
I was planning to start on the window wall, but need some advice first....The tiles are 8 mm thick, the tile bead/edging for the external corners, at the local suppliers, is in various sizes..... seems like my choice is between 9.5 mm, or 12 mm, but the 12 mm looks quite big, and bulky...
does 9.5 mm edging sound like the right size?, and when I fit it, does it go on the wall, or the window reveal?, do I leave a gap to grout, between tile edge, and the tile trim?, or butt right up to the tile, with no grout?.
Is it best to mix adhesive with drill and "mixer", or can i do it, with a trowel?
Should I leave a gap where the tiles meet the window frame, and fill with grout, or small bead of silicone, or....?
....and if there's any more tips/hints etc.... would be very grateful
Sorry about the long post !!, but I really want to do the best job, i possibly can, and be proud of it!
