Z
zzr-matt
Its been a few years since I was last on here but I'm back as I have another bathroom to do 🙂 This time I'm using 300 x 600 porcelain tiles. The local tile place is a Granfix stockist. They used to be Mapei so previously I used Primer G, Keraflex Maxi and Keraquick with latex additive. Whats Granfix like compared to Mapei?
This one has a selection of issues:
1. The walls are 75mm light weight blocks with a 10mm render with a 3mm skim on top. Unfortunately the skim is not stuck to the render and just comes away. The render (not sure if thats the correct name) is hard but feels a bit dusty to the touch. Much like if someone had just blown a load of building dust over it. Once I have scraped all the skim off I assume I can prime this and tile straight on?
2. I need to build a small section of stud wall in a shower enclosure. I was going for aquapanel onto the studs, tape the joints then tank the area before tiling. Does that sound ok?
3. The flooring is a mixture of P4 / P5 chipboard on joists at 450 centres. I was going to go over this with 12mm ply screwed to the joists and chipboard below but from what I have now read on here no more ply 6mm may be the way to go? Does this need to be glued and screwed?
Can anyone recommend the best Granfix adhesive to use for the above?
