Discuss Bathroom wood floor in the Bathroom Tiling Advice area at TilersForums.com.
robbieraven
Hi all,
About to start a bathroom floor for some friends in a couple of weeks, I'm relatively new to this so appreciate some advice, on lifting the carpet I noticed it's a mix of ply and chipboard, and seems relatively flat and sound, I have rad much about the movement of wooden bases, so I thought about laying new 6mm ply, with the tiles on top too the height is going to cause a few snags. Then I thought I could Dita it, be good to learn something new? Any thoughts?
Thanks Rob
nybor62
1,083
rotherham
6mm ply is big no no
can you not remove the ply and chip board and replace with min 15 mm wbp ply then over board with 10 mm cement board glued and screwed
i understand were ya coming from with the height issue , if your floor is sound with no deflection you may be able to over board over the top with 10 mm cement board again glued and screwed
what tiles are you laying
I
ian158
Whilst most on here say a big no no to 6mm ply, I ripped up a bathroom in ashover Derbyshire last year, this had 6mm ply nailed to floorboards, it had been down since 1984, all I can say is, it was one hell of a job getting them up. There was no cracking, the bathroom was fine, just needed updating, not condoning it but 20years and it was fine !!,,
Reply to Bathroom wood floor in the Bathroom Tiling Advice area at TilersForums.com
gamer1
6K
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
Bathroom wood floor
Unsolved
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
