DHTiling
The Dewalt D24000 is back in stock from Trade tiler..
DeWALT D24000 Wet Saw
Genuine DeWALT- UK supplied stock (beware of imports) - 30 day 'no quibble' money back guarantee
Instruction Manual
Tradetiler Wet Tile Saws
![d2400-2blades.jpg](/proxy.php?image=http%3A%2F%2Fwww.tradetiler.com%2Facatalog%2Fd2400-2blades.jpg&hash=513d16eb1e10252cddb425fe243b5fd4)
- Stainless steel rail system is intergrated into the tile saw frame, ensuring super accurate cuts
- Relatively low weight allows one person to transport and set up saw
- Intergrated 45/22.5° feature for quick angle cuts
- Plunge feature allows the user to make quick plunge cuts
- Dual water nozzles can be adjusted on the blade in order to minimise over-spray and mist
- Rear and water trays can be placed on the tile saw to catch overspray - keeping the water in the pan
- Removeable cutting cart for easy cleaning of tile saw
- Repetitive cut guide with two positions - 90° & 45°
- Integrated portable residual current device (PRCD) circuit breaker for increased user protection
- Power Input: 1600 Watts (240v) - 1500 Watts (110v)
- Wheel Diameter: 250 mm Bore 25.4mm
- (Wheels as small as 150mm can be used but we recommend 180mm minimum)
- No Load Speed: 4200 rpm
- Main tray 690mm wide x 890mm long
- Using back tray increases length by 400 mm
- Sliding cart 430 x 430mm
- Side extension table adds 230mm to right
- Using side drip tray increases overall width to 900mm
- Height adjustable to 3 levels
- Weight 32 kg
- Max cut length: 760mm (plunge and cut)
(can be increased to over 1,000mm by plunging and turning tile) - Max cut lenght: 660 mm (no plunge)
- Widest tile cut in half at 90° 660 mm
- Widest tile cut in half 45° 450 mm
- Max depth of cut: 95 mm
(Motor pillar 150mm back and 330m to left of blade)
- Extention side table
- Side and rear water collector
- 2 x hex key and blade spanner
- Support leg set
- Free 12 months servicing contract
- 12 months guarantee
- 2 x Dewalt Premium porcelain blades Included
Instruction Manual
