View the thread, titled "Best solution to minors works certs for over 100 circuits only altered with a 2m cable from an isoltor to a plug? Electrical Advice" which is posted in Electrical Advice on UK Plumbers Forums.
Best solution to minors works certs for over 100 circuits only altered with a 2m cable from an isoltor to a plug? Discussion ThreadBest solution to minors works certs for over 100 circuits only altered with a 2m cable from an isoltor to a plug? Electrical Advice
I have a situation where we have altered nearly 100 new circuits purely by adding a cable from the supplied isolator to a 3p+n plug to supply pumps. Each isolator is on its own circuit from the local DB and we need to issue certs for all these alterations, I was curious if there was a recommended faster way to cert all the alterations as 100 minors works certs seems a bit excessive.
Best solution to minors works certs for over 100 circuits only altered with a 2m cable from an isoltor to a plug? for the original thread on Electricians Forums
Reply to the thread, titled "Best solution to minors works certs for over 100 circuits only altered with a 2m cable from an isoltor to a plug? Electrical Advice" which is posted in Electrical Advice on Electricians Forums.
