Tiling Tool Suppliers
Discuss Best tile cutter you've used for cutting 1500 mm long tiles?? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com.
I am thinking of buying montolit FL3 flashline.
The last time I had to cut 1500mm wood effect tiles 10mm with my Rubi TC-125 circular cutter kit.
Sigma makes one that cuts ridiculously long tiles quite thinly.
With sigma you can progressively break along the scribe line instead of at one end.
Carrying it around is a pain
Wet saw keeps the dust down and ok if you are skirting over the cut.
If its for occasional large jobs Id hire one as day rates are quite cheap
I second the sigma. I’ve used the montolit flashline without suction cups and it was tense scoring 2400x1200 wall tiles (£700 each!!) and definitely a 2 man job. I’m biased towards Sigma, i know it’s more expensive but you get what you pay for and the suction cup supports are invaluable.
Reply to Best tile cutter you've used for cutting 1500 mm long tiles?? in the Tile Cutters (Manual & Wet Cutters) area at TilersForums.com
Hi everyone, I'm not a regular tiler, just someone who is trying to fix up a few rooms around...
I need advice on score and snap cutting of large porcelain tiles, lets say, over 1000 mm long...
I’ve got a job using marble geometric mosaics about 10 mm thick. I’ve tried several blades to...
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Popular Tile Cutter Threads
ceredigion
What member type are you?
  1. Contractor
    Votes: 9 5.5%
    Votes: 17 10.3%
    Votes: 12 7.3%
    Votes: 46 27.9%
    Votes: 21 12.7%
    Votes: 39 23.6%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.5%
    Votes: 17 10.3%
    Votes: 8 4.8%
    Votes: 2 1.2%
    Votes: 5 3.0%
