Discuss Best Tile Layout Opinions in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com.
Robert19306
Ok guys following on from my thread on cutter for 600x600 could I have some opinions on layout for this space of possible. The plan is to tile the Hall kitchen/dining and sunroom all with the same tile which is 56.5x56.5 polished porcelain. The lady who supplied the tiles recommended to tile straight through kitchen/dining/sunroom starting in middle of the kitchen and tile hall separately with a mosaic of the same tile separating them at the doorway between hall and kitchen. The narrow end of the kitchen is working out with around a 3/4 tile on both sides of cantered and the wide part will end up with a 3 inch or so tile under the kitchen units at the window side which might be ok.
Any opinions on layout would be much appreciated as I have a bit of work to do before I start it preparing screed.
Cheers
James.
Reply to Best Tile Layout Opinions in the Tile Retail | Wholesale | Import / Export Tile area at TilersForums.com
  • Question
Hi all, I've laid some Arditex NA over the kitchen floor area (not under cabinets. The area is 4.5m x 1.8m. The top third of the room is totally level. The remainder of the room has a slope...
