Martino
I have been asked to make a hearth tile it and tiles the walls....they are having a log burner fitted into a corner of the room..
Am i right in thinking...
A concrete harth with porcelain tiles will be suitable......and i need to replace the norman plasterboard with hardie backer board?.....and use porcelain for these too.....is there a set width i need to cover for the burger? e.g if its 400mm wide would a 1m span be enough? so like 300mm to each side
